I hope i have posted this topic here correctly.
I have used aviNET before and the program worked fine. Tonight i installed the latest version (v2.5.0.0) and uninstalled 2.2.2.0. Again the program works fine, but the end result has very poor quality. (blurred and out of focus)
Do i need to install something else to get better quality?
I have looked for the old version on the internet. I found a link, but it doesn't work. What can i do to get a better quality .avi file?
Are you converting to xvid? be sure to install the latest xvid 1.1.2.
http://download.videohelp.com/download/aviNET2220.zip -
Thanks for replying Baldrick.
I downloaded aviNET from the tool link on this site. I also downloaded the avi.support package which includes Xvid v1.1.2
Do you have any other ideas?
Thanks for the link for version 2.2.2.0. I think i'll download that version tomorrow if i am unable to get the quality i want from the 2.5.0.0 version.
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
