I just read that a guy had a problem with some TY's and didn't know if it was the TY's or the Drive. And he got his TY's form Super meida store and FulciLives said that they TY products are questionable.
But my problem, I have a post somewhere else that talks about my drive only burning single layers and not DL,
caus every single I get it spits it back out "no probelm" but when I put a DL in it'll burns to aboat 15-20% don and then my system spits out the bad dvd. one burned completely but it failed the data check and I've made costers out of about 8-10 for 'em.
So now I'm thinking it's probably the company that sold 'em to me cause I only buy from Rima Meritline or some last store but I'll have to go home to look at my Bookmarks to say. Any way ... Could it be the whole bundle of DL's or my drive cause it didn't start messing up until the first 3-4 disc
I was told that and I updated the firmware and it did that same thing
When I get home I think I'll try it again. but please keep the suggestions commeing -
Well, you never said what "brand" of DL media you are using.
I've burned a few hundred or more value TYs from Supermediastore on an NEC 3500, the few times I had problems were defective discs that I could have seen were bad if I'd looked at them first.
I've burned a few thousand of the TY valueline from Supermedia the past couple of years and can probably count on my hands and maybe one foot the number of bad discs. I've used a Samsung, a BenQ, a Nec 3500, Nec 3520a, and now I have two Nec AD7170A and they all have done the job on single layer or DL with the correct firmware. If you are using TY from Supermedia then I would have to think you have a drive problem or firmware problem.
NEC ND-3500AG DVD RW DL burner doesn't recognize blank DVD's
By renegade431 in forum DVD & Blu-ray WritersReplies: 38Last Post: 8th Feb 2009, 06:16 -
Is it easier on the burner to use R or RW media?
By PuzZLeR in forum DVD & Blu-ray RecordersReplies: 25Last Post: 28th Nov 2008, 11:40 -
LightScribe Media with Sony Burner.
By dragonsbb16 in forum MediaReplies: 11Last Post: 14th Dec 2007, 20:44 -
I need a 100% reliable burner and media.
By sneaux in forum MediaReplies: 36Last Post: 17th Jun 2007, 17:00 -
After a new burner and media.
By SE14man in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2007, 10:03
