Hi there,
I am trying to burn multiple MPEG's and the first few work fine off the menu but then the rest usually are garbled on the screen and I am unsure why.
Any help is appreciated.
RGDS & TIA
Curtis M.
Post your log file.
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Can't tell much from that log as all the files are already processed previously. Can you identify one of the files which is giving you issues, and then try it on its own (from the original) and then see if it still has a problem. If so can you post that log?
Tried one on it's own and the problem did not show up so I will try again on a new disc and see if that fixes it.Originally Posted by ChrissyBoy
Thanks so far
Curtis -
Ok. Could be a media issue...
Hi there,
I'm having the same problem with other files and I'll attach the log:
THX
svcd2dvdlog-20070429215741.txt -
Well that log doesn't help much as the asset has already been processed. Have you got the log of the conversion? Also you seem to be low on disk space - so i am suprised it is completing the whole DVD....
Split Avi to DVD creates Video_Ts folders w. garbled video intro. Help?
By wildgeese in forum ffmpegX general discussionReplies: 7Last Post: 10th May 2011, 18:56 -
Garbled subtitle texts
By Bujila in forum MacReplies: 2Last Post: 18th Jan 2010, 10:19 -
Every DVD is garbled...
By 10xOXR in forum Authoring (DVD)Replies: 5Last Post: 6th Aug 2008, 10:11 -
Garbled Audio in Nero Dvd project - Video is fine - need assistance please
By RossChurchill in forum Newbie / General discussionsReplies: 2Last Post: 17th Jan 2008, 16:44 -
Audio is garbled in WMP when viewing video clips
By mowermanEd in forum Newbie / General discussionsReplies: 2Last Post: 8th May 2007, 03:48
