Nearly all FLAT TVs has a light source that will need replacement after two or three years.
* Plasma direct view TV uses plasma cells.
* LCD direct view TV uses EL light sources.
Direct view TV light sources will faded overtime. How long do they really last, and can the TVs be renewed ?
* LCD and DLP front and back projectors TV uses lamps.
The lamp in projection TVs tends to fade or die after a few years. I found out many front/back projection TV lamps are really difficult to get hold off. Without a working lamp the TV is useless.
Are majot labels like panaosonic, toshiba, jvc, sony, pioneer TVs lamp available from factories or retailer, or is this a dice toss ?
I would suspect they would be available from the bigger electronic parts retailers, they should also be available from the manufacturer. There are always exceptions of course, especially if you are dealing with a model that was replaced by newer technology.
Google is your Friend
Interference from Incandescent heat lamp
By Bshanahan in forum Capturing and VCRReplies: 6Last Post: 19th Feb 2010, 15:37 -
more lamp time on my PT-AE900U
By ratboys in forum Newbie / General discussionsReplies: 0Last Post: 24th Jun 2009, 23:40 -
Is it safe to replace a projector lamp yourself?
By yoda313 in forum Newbie / General discussionsReplies: 35Last Post: 17th Sep 2008, 13:21 -
Water for Gas?
By MeDiCo_BrUjO in forum Off topicReplies: 2Last Post: 17th Jul 2008, 17:10 -
Reduce noise on low light sources
By cd090580 in forum RestorationReplies: 2Last Post: 17th May 2008, 09:44
