I'm editing a commercial DVD movie.
The main content is 24fps progressive with pulldown flags.
The deleted scenes are 29.97 interlaced. I assume I need to convert the deleted scenes to the same format as the main film to work with them together.
I am guessing the first step is to inverse telecine the deleted scenes to 24, convert them to progressive and then run them through GPpulldown (or whatever it's called) and "convert" it from 24 - 29.97 with pulldown flags.
Am I right so far?
Do I just load the clip into TMPGenc, click IVTC, then deinterlace with either VD or TMPG?
I have not gotten the hang of AVIsynth and would prefer to use these "simpler" tools.
One other questions... GPindex lists the 24 material as having a field order of "top," while the deletes scenes are "bottom." Can progressive material really have a field order, and does this mean I should change the field order of the deleted scenes to match?
Thanks!
deleted scenes are often from vids and are native interlaced -- you dont need to deinterlace .. you can have mixed in your dvd ... they might also be a different aspect ratio .... that you shouldnt really mix
Ok, I did the IVTC with Vdub and it looks great - perfectly smooth motion now.
One thing that surprises me - there are no field artifacts at all even in fast motion - the frames look progressive. Do I still need to deinterlace them?
Even if it's true that I don't *have* to convert it, I like the idea of all the material in my project being the same kind of source - I was having problems earlier with stuttering video and it began once the first deleted scene came up - so by turning into the same format as the main film, I'm hoping it's fixed. -
No, the whole point of IVTC is to restore the original progressive film frames. If it's done properly there will be no comb artifacts.Originally Posted by mojo
With a few short scenes VirtualDub's automatic IVTC might work out OK but it's not reliable in the long run. You'll eventually start finding jerky scenes and interlace artifacts sneaking through. You're more likely to see problems with smaller motions or low contrast scenes because the comb lines are harder to detect then.
VirtualDUb's manual IVTC is perfect if your source is clean and free of pattern breaks.
Need help IVTC a video
By drawar in forum Video ConversionReplies: 16Last Post: 31st May 2011, 22:29 -
IVTC - could someone help?
By Gew in forum Newbie / General discussionsReplies: 51Last Post: 8th Feb 2010, 21:26 -
Why can IVTC not be perfect?
By loekverhees in forum Newbie / General discussionsReplies: 12Last Post: 31st Oct 2009, 17:51 -
ivtc help
By iamtehsux in forum Newbie / General discussionsReplies: 3Last Post: 20th Dec 2008, 19:58 -
IVTC Help!!!
By Martig in forum Video ConversionReplies: 1Last Post: 11th Jan 2008, 01:43
