I'm trying to capture directly to DivX (low motion) from TV but whatever settings I use it's always too big. I want it to be no bigger than 1 meg/min but the best I can do is 17megs/min. I'm using Vdub with a framerate of 29.97, audio 44k/16/s, DivX low motion codec, 320x240 YUY2. Here's a pic of vdub after 1 minute of recording.
www.geocities.com/divx_edu/tvcap1.jpg
Oh yea, I've also noticed if I try to capture at anything other than 19.98, 29.97, 59.94 I lose frames like crazy. So if I try to capture at 20 fps I lose frames but not at 59.94. Why is that?
Thanks,
Mike Shaffer
AMD ATHLON XP 1700+ CPU
ABIT KR7A-R MOTHERBOARD
512MB PC2100 RAM
SONY 21" TRINITRON CPD-G520 MONITOR
ATI ALL IN WONDER RADEON 8500DV 64MB NTSC
ENERMAX FS-710BB 330W FULL TOWER CASE
SONY SPRESSA 16X/10X/40X EIDE INTERNAL CDRW
CREATIVE LABS SOUNDBLASTER LIVE! PLATINUM PCI 5.1
SONY 16X DVD INTERNAL EIDE DRIVE
IBM 60GB 7200RPM HARD DRIVE
KLIPSCH PROMEDIA 5.1 (500W) SPEAKERS
for starters you need to compress the audio which will cut the size of your file in half
i'm no expert but 1 meg a minute aint ever going to give you good quality with divx. i've downloaded some decent stuff at about 2mb/min but its still not great looking
as for the dropped frames at different frame rates being reported, i think that is some kind of compensation for audio/video sync, you may not actually be dropping those frames. search the forum there is a good explanation there somewhere. -
buddy, you have a great pc setup with ample HD space. why not try capturing MJPEG then compresing to divx and mp3 after? try SBC for best results in small AVI file sizes...
later bater. deltaboy
Test of various VCRs Image Quality from VHS Tape (Big Pics)
By BrainStorm69 in forum RestorationReplies: 47Last Post: 2nd Aug 2013, 15:58 -
big headache with capture card and new nxp chip
By mammo1789 in forum Capturing and VCRReplies: 5Last Post: 26th Jan 2012, 12:11 -
Upscaling 480p vid to 720p without big quality loss.
By MousE0910 in forum Newbie / General discussionsReplies: 11Last Post: 8th Nov 2011, 12:31 -
WMV to DVD without any change in quality?
By Mudchild in forum Newbie / General discussionsReplies: 4Last Post: 17th Nov 2009, 02:37 -
All Frame's Capture to show In one big Pic . ??
By lostnucleus in forum Newbie / General discussionsReplies: 11Last Post: 28th Feb 2008, 04:24
