I've copied over several old VHS tapes to DVDR's on my LG RH1777 DVD Recorder. Checked each and plays fine on that unit. Now, find none of them play on my other LG DVD player or portable player. VERY frustrating! This has also happened with a video which I burned via the DV connection from my video camera. Any suggestions?
I would suggest the folowing procedure:
1. Copy the burned video files to the computer
2. Demultiplex to elementary audio video streams.
3. Reauthor as a standart DVD-Video (VIDEO_TS)
4. Burn to disc.
Now the problem is I don't know how to accomplish this on Mac. Well, good luck. -
It sounds as if you didn't "finalize" those DVDs after
recording. Gotta do it or only the producing machine
will be able to read them.Al Bloom -
FYI: Recordable media aren't compatible with some machines.
However, you might try re-authoring your discs on your computer and see if that works...
http://www.dvddemystified.com/dvdfaq.html
Also, always use quality discs marked "Made in Japan." Taiyo Yuden is the best, IMO.
dvd player wont play AVI or dvd video burned discs
By rockerman in forum Authoring (DVD)Replies: 5Last Post: 20th Oct 2011, 14:01 -
Issue getting burned dvd-r to play in Sylvania portable dvd player SDVD8727
By deviant_delusion in forum Authoring (DVD)Replies: 2Last Post: 18th Aug 2010, 19:02 -
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 13:55 -
Dual Layer DVD successfully burned, but won't play on a DVD player Help Plz
By Ruudboy in forum Newbie / General discussionsReplies: 9Last Post: 13th Dec 2008, 03:09 -
DVD-R burned using a DVD Recorder wont play on any other player
By weaseal4 in forum DVD RippingReplies: 4Last Post: 22nd Oct 2007, 12:37
