I just finished with encoding cast away.... (from Divx 2 VCD)
Before i started, i tested it a couple of times, and it was great...
very good quality..
But now.. 4 hours later... it comes out crappy
The beginning of the movie is good!!! but later on
it looks like it is playing "fast forward", like:
if you have 10 sec. of movie, it plays in 5 sec... 2 times as fast..
and the sound "crispers".. and skips parts...
I'm getting pist off to all this shit... isn't there a program AllIn1
that convert DIVX3/4 to VCD/Dat...
I now use
TMPGenc.. (where it whent wrong(encoding from divx 2 VCD))
and Virtualdub (i extracted the audio first)
I just dont know what to do any more ...... i could cry,
but i wont.... cause im tough....
__________________
As long as my boss thinks i make a lot of money, i will pretend to work hard
like most people say DivX is the most worst Video source for encodeing...but first make sure you have the latest codec and put motion search to Highest
People can say what they want, But this movie is of extreem good quality...
So is the encoded Mpeg1/VCD file,, but it just plays wrong..
i will give it a try (to set the highest motion)
Thanx 4 your reply..... -
Make sure you use the correct frame rate in TMPGenc, highest motion search and check that "No motion search for still picture part by half pixel" is unchecked (it's under Quantize Matrix).
Another thing to try is to encode video only, then encode the audio with toolame and mux them together using bbmpeg. -
I've done it again..
and again the same results....
The 1st 15 min. are fine... but then it's start to run twice as fast, causing the sound to "skip"... i think.. because it wants to be in sync. with the video stream..
i extracted the audio with virtualdub:
video --> full processing mode
--> Compression: no compression PCM
save wav file: it's sice is about 763 mb's... pretty normal.
If i play the sound file, there's nothing wrong with it.
Then i open TMPGenc,
browse to the video file..... added
Browse to the (extracted) audio file .... added
I load the standard Template: video-cd PAL...
3 hours later....... &*#^$(#.....
and another day waisted... .....
I beginning to get nuts here.. -
Whats the framerate of your divx? Probably 23.97fps, pal framerate is 25fps that will cause sync probs. And umm... if the audio is vbr mp3 your probably wasting your time.
No... i changed the fps from 23.... to 25..
how do i check if the audio is vbr mp3... and what is that exactly????
RipBot Encoding Wrong Language
By andy6590 in forum Blu-ray RippingReplies: 7Last Post: 1st Apr 2011, 15:20 -
2 pass encoding / Wrong final size
By stanfield in forum Newbie / General discussionsReplies: 26Last Post: 9th Dec 2010, 08:22 -
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 09:32 -
Wrong image size ratio after AVI to DVD encoding
By video34bgi in forum Video ConversionReplies: 2Last Post: 22nd Jun 2009, 10:45 -
Wrong number of chapters on ripped DVD precludes encoding
By headless chicken in forum MacReplies: 3Last Post: 2nd Sep 2007, 14:26
