    Jul 2001
    I have an ATI All-In-Wonder pro capture card. When I Capture a video from my Dgitial Video Camera it saves it in AVI format. Is there a way to capture it in MPG VCD Format or do I have to save as AVI then convert it.
  2. If you are taking a firewire link between your DVC and the ATI card, then that will be saved in a variation of an AVI format. To capture MPEG's directly, you need to use the composite input on the ATI card itself, and make sure that the cap software is set for MPG capture.
