Here's what I need to do. Just looking to transfer old vhs movies to DVD. Home movies from an older Sony Camcorder as well. Want the machine to be hackable so that it's macrovision free. Want something that's not going to give up on me after only a few months as I have numerous tapes I want to dub. I am also going to want to be converting these files to DIVX so that I can put everything on an external drive and use my Phillips DVD player with USB port to play all of them on. What are my options here. So far I'm looking at the Walmart SV2000(unfortunatly no hacks that I'm aware of at this time). Any suggestions. Looking to put everythign on DVD+R
The Lite-On units from a year or two ago can be hacked MV free, or purchased already hacked.
Search eBay for the following models:
LVW-5005
LVW-5006
LVW-5007
LVW-5001
These are Lite-On clones that can be hacked:
ilo DVDR04
Gateway AR-230
The other option is to get a video "clarifier" like the Sima GoDVD. These boxes will let you record VHS to any DVD recorder. They hook up in between the VCR and the DVD recorder to defeat the MV signal. -
Looking for something that's still on the market that can be purchased at Best Buy, Walmart,Target,etc. Something that can be taken back in case anything goes wrong. I'd be leary about buying on eBay.
If you're going for MV + Region Free in the USA, then you're going to be using hacked software, which will invalidate your warranty anyway.
Is there such a thing as a reliable DVD Recorder?
By V Bot in forum DVD & Blu-ray RecordersReplies: 22Last Post: 25th Jul 2010, 14:29 -
need a budget dvd recorder that's region-free or hackable
By hankhandsome in forum DVD & Blu-ray RecordersReplies: 0Last Post: 28th Jul 2008, 08:30 -
Wanted: inexpensive DVD Recorder/VHS Combo unit that is reliable
By Kmical in forum DVD & Blu-ray RecordersReplies: 4Last Post: 20th Feb 2008, 11:57 -
DVD recorder/VCR recommendations-region free or hackable?
By jedbu in forum DVD & Blu-ray PlayersReplies: 2Last Post: 1st Oct 2007, 12:09 -
I need a 100% reliable burner and media.
By sneaux in forum MediaReplies: 36Last Post: 17th Jun 2007, 18:00
