Hi all. i am using pctv analog pro tv. some of my captured files from satalite reciver the sound for the left speaker is missing when i hear to captured files. could any one tell me what might have caused the problem and is there any solution to fix it or i have to re capture again? I used rca cables to connet to my reciver.Thanks
Are they stereo cables ?
Are they good cables ?
You can fix the caps you have by copying the right channel over the missing left, effectively giving you joint stereo, or 2.0 mono. But you need to check your cables and connections to work out why you are not recording down both channels.Read my blog here.
Audio from device via rca (left / right channel) to rca : stereo headphone conversion cable .
Could also be an issue with capture device ... need to check that after cable has been confirmed .
Audio quick fix :
Depending on what is required output ... vdub for avi , vmod for mpeg .
Either way , demux audio as wav .
Open vdub , load any avi , under audio , set to full processing , then choose wav ... locate that audio stream just created .
Go to audio , conversion .
44.1khz for mpeg ... 48khz for mpeg2 .
16bit , stereo .
Save as wav .
Convert this new wav as required . -
Thank u for all of u . bjs. Is it possible to use vmod for video_ts folder ? i already burned the files in dvd. or do i have to do this on mpeg2 files and re render all togther? it would be nice to to fix this using current vobs. i be happy if hear from u guys.Thanks
bjs i got problem using virtualdub for mpeg2 files what has missing left speaker voice!! I get the error shown in pic
attached pic
DVD-R sound coming through only one speaker
By Marshfish in forum Newbie / General discussionsReplies: 5Last Post: 7th Sep 2011, 02:40 -
Edited sound jumps from speaker to speaker
By len hend in forum AudioReplies: 3Last Post: 23rd Jul 2010, 06:49 -
DVD missing left channel...
By xichael in forum DVD RippingReplies: 2Last Post: 31st Dec 2008, 17:13 -
Mitsubishi announces LCD TV with integrated 16-speaker surround sound syste
By joytimeday in forum DVB / IPTVReplies: 2Last Post: 11th Jul 2008, 10:11 -
Help: Sound only plays from left speaker
By rdc in forum AudioReplies: 5Last Post: 31st Dec 2007, 22:25
