... maybe I'm doing something wrong -- I am a newbie, you know? I extracted (is that the word?) an iso file. MySonic tries to play it and says "invalid-something" and then I click the OK button and the MySonic program opens up as if I want to edit and create a DVD or something. This is what I've done so far
1) d/l .iso file
2) t'fered .iso file to CD
3) got isobuster
4) ???? why isn't this working????
Thanks,
Moe B Disc
Results 1 to 13 of 13
What are you trying to do?
He's a liar and a murderer, and I say that with all due respect. -
Zipgenious can extract content from iso .
If under 800mb's , assume cd .
If over , assume dvd .
Mount image file using microsoft's utility , or the sheep found here :
http://www.softpedia.com/get/CD-DVD-Tools/Virtual-CD-DVD-Rom/Virtual-CloneDrive.shtml
This one atleast use's a sheep icon so you know which drive is where ... brilliant ... no issue's .
Burn with imgburn once the iso has been figured out ... -
As steveryan stated, it helps if we know what you are trying to do. ISO files are just disc images. Open up your burning program, load the image, burn to disc and enjoy. If you are trying to do something else, then burning isn't necessary, but we need to know what you are trying to do.
Google is your Friend -
I received a computer program which is in a .iso file. I would like to use the program.Originally Posted by steveryan
M_B_D -
Open the image in your burning app and burn to disc OR use a program such as Alcohol 120% to mount the image and play directly from the iso.
After I d/l the program, I used Nero to burn to a CD-R. It was suggested to transfer it as an image, so I did. I tried other ways to transfer it, but they didn't work. I still don't understand why I needed to t'fer a piece of software as an image, but that what I was told would work.Originally Posted by TJohns
When I try to open the CD-R with the software, my computer takes me to Sonic MyDVD and I get a message box that opens and says "this is not a compatible file" or something to that affect with an "ok" clickable button. When I click "OK" Sonic MyDVD continues and opens as if I want to edit a DVD project.
MBD -
Here is exactly what I did -- just tried it again.
1) place .iso file CD-R into drive.
2) open isobuster
3) choose run and extract
4) after #3, the following message pops up: "This Is Not A Valid MyDVD Project File"
5) click "OK"
6) Sonic MyDVD prgram opens as if I want to create/edit a disc.
Now what???
MBD -
If that's the case, and you HAVE burned the image correctly to CD, then there's no reason to be using ISObuster for anything at all...put the CD into your computer, open the MY COMPUTER icon, open the drive corresponding to the CD. You should see eitherOriginally Posted by moe_b_disc
1) a single .ISO file = you DIDN'T burn it as an image
2) some folders and/or EXE files = look for SETUP or INSTALL and double-click it
3) a VIDEO_TS folder = it's actually a DVD movie disk; use MPC or similar to play it
4) an MPEGAV folder = it's a VCD or SVCD movie disk
5) various *.CDA files = it's an audio CD
6) who knows????
some details on what you can actually see, rather than explanations of what you're trying to do would help out
Trevor -
This is what I see: When I go to My Computer, I see that a CD-R is in the E drive. When I click on that, I see an icon with the CD-R's title. When I place the pointer over the icon, it says, "Type ISO file," "date motified," and "size."Originally Posted by TJohns
MBD -
So, if you see an iso-type file, you have to mount this (with Daemontools) as virtual CD.
Or, as I stated above (twice), burn the image to disc (NOT as data). You can also READ the STICKY at the top of the forum.
Trying to extract VOB file with Isobuster, nothing happens?
By dai3504 in forum DVD RippingReplies: 2Last Post: 8th May 2011, 11:42 -
Tool recommend for *.avi ---> DVD(iso) and ripping a DVD to *.iso file?
By pxstein in forum Authoring (DVD)Replies: 4Last Post: 11th Jan 2011, 16:51 -
MPC with K-lite codec pack won't play ISO movies in Windows 7
By Monsoon in forum Newbie / General discussionsReplies: 9Last Post: 5th Dec 2010, 22:28 -
Why won't my VTS_01 file work on windows movie maker?
By LITEONDVD in forum Newbie / General discussionsReplies: 2Last Post: 21st Jul 2007, 11:13 -
DVD (ISO) Plays Fine on PC, Won't Play on Standalone
By MoneyAddyct in forum Newbie / General discussionsReplies: 1Last Post: 17th Jul 2007, 22:15
