  1. When using ReMPEG2, like the guide for "Copying DVDs that are larger than 4500 megs" says to, when the program reaches 99% it seems to freeze up. It says it has 1 second left to finish, but never does. Has anyone seen this or know what to do.
    ReMPEG2 - v. 1.5.2
    1.2 Ghz
    256 Memory
    30 Gig HDD
    Also tried on a 1.47 Ghz
    512 Memory
    20 Gig HDD
    Same thing happens. PLEASE HELP.
  2. Hi, would you let me know where can i get this program rempeg2. sorry couldn't help your problem as i was stuck at this situation.
    thanks
  3. tHANKS, I appreciate your help.
    I hope i will make it if possible to suceed, as first time try.
  4. Mine does the same thing..... what i usually do is wait till it gets to 99% and then when it freezes wait till about the time that it should be to 100% then shut the program down..... It seems to have finished the files but just wont display 100%.... i hope this helps.
    Also is anyone having trouble recompressing the clips with ReMPEG2... after i do they seem to play really really fast when played back through Win DVD.... The lower i change the bit rate to the faster they play (i mean like in fast motion... the video looks like its being fast forwarded).
  5. HOw do you recompress the M2V file....what do I do next???
