I just bought a new 32 inch samsung LCD TV (LN-S3241D) and Im trying to hook it up to my comp...but the resolution on my comp only goes up to 1280 X 1024 but I think the resolution has to go up to 1360 X 768 in order for it to show up on my new widescreen TV. I have a Dell Dimension 3000 and theres no graphics card or anything. Am I just out of luck or is there a way to up the resolution without having to buy a graphics card or any othe hardware?
Have you tried Powerstrip, http://www.entechtaiwan.com/ ?
The TV has a VGA in-put just like the back of a normal computer monitor. So its not like im out-putting through a s-video cable or something like that....im plugging my vga cable directly from my comp to the tv. So even if my comp were to notice a difference in monitors, i wouldnt be able to see anything to even change it.
Megui Resolution problem
By thezanny in forum Video ConversionReplies: 3Last Post: 9th Mar 2011, 09:34 -
HD Movie resolution problem
By Penicillin in forum DVB / IPTVReplies: 3Last Post: 21st Jul 2010, 16:18 -
Half D1 resolution problem
By sebrame in forum Authoring (DVD)Replies: 9Last Post: 30th Jul 2008, 10:18 -
Why does this happen? Resolution problem.
By bananadude in forum EditingReplies: 8Last Post: 14th Jun 2008, 03:47 -
HD TV Resolution Problem
By jemoto in forum DVB / IPTVReplies: 9Last Post: 29th Mar 2008, 05:45
