My setup is:
PIV 3,0 GHz
memory: 1,0 GB
HD: 7.200 rpm
I capture using Mainconcept 1.42 (because 1.51 wont work for some strange reason.)
Realtime-Capture settings:
Buffering: ON
type: DVD-PAL
resolution: 720 x 576
Video bitrate: Variable 6500 kbps
Encoder quality: 40
During the capturing the CPU goes up to 80% and at random intervals I hear cracking and ticking sounds. Sometimes the video even stops very shortly.
The finished product is just fine. So the sounds and the stopping of the video is not captured. But it is annoying as @#$%!!!!
I have tried turning off all other services and just running MC, but nothing helps!
please advise!
Results 1 to 21 of 21
Probably the PC's fault for the stoppages. Especially with that high a CPU load. That seems unusually high for a 3 GHz P4
My 2.8 would sit at about 10% during video capture.
Do you know what your HD's throughput is during capture? Perhaps there's a bottleneck at the HD. Check in Device Manager to make sure you're running the HD in DMA mode and not PIO mode.
I would try and find out why the newer version of the capture app won't work, and fix it. That also could be where the problem lies. Have you contacted their tech support yet?
The other stuff - the popping and clicking sounds like a sound card issue. -
1. I am capturing realtime into MPEG-2. I can not imagine that you are capturing into MPEG-2 only using 10% of the CPU! You probably capture into DV-AVI lossless.
2. I will indeed see what is going wrong with the newer version of the capture software.
3. What could be the sound card issue? It only happens caupturing, not during any other playback! -
just tested 1.5.1.
The problem is that the captured file sounds "double". Like you hear everything double!
any ideas? -
Originally Posted by jochenzJohn Miller
Originally Posted by JohnnyMalaria
With or without the preview, the CPU goes to 100%.
strange, since under version 1,4 the CPU would only use 80% MAX!!! -
Now, if the newer version takes longer, then that suggests a bug that is creating a "race" condition, where one thread is waiting for another to finish something - but it's waiting for the first one....as so on forever!John Miller -
My CPU support Multithreading. So perfomance should be better? or not?
A dual core CPU can run two threads at the same time.
A P4 with HT can do so, too (kind of).
However, a heavily-multithreaded application can suffer on a single CPU. If the software spends a lot of time trying "to be clever" and create lots of threads, it does so without benefiting a single CPU system. Time gets wasted managing the threads.John Miller -
owkeeej, but what does this mean for me?
How will this solve my ticking and cracking? -
I don't think it will.
If you only see the chopping and hear the cracking during capture, it is because the software is ensuring that the more important part - writing the file to disk without loss - happens.
What kind of audio hardware do you have?John Miller -
I'd turn preview off to reduce CPU decode load. I haven't seen the problem myself since I usually monitor upstream of the encode. -
The Sigmatel audio requires a lot of CPU time - especially if you have any equalization or surround processing. Turn off all the additional processing.
Is your graphics integrated, too?John Miller -
My capture box is listed in my "Computer" details. -
But for some reason I had no problems using the older version! SO.....how come it would be causing problems now?
I have absolutely no extra processing going on! So that can not be it!
Yeas I also have graphics integrated. NVIDIA card! why? -
Comparing the two versions of your encoder, does the newer version take longer to encode the same file?John Miller -
I have been testing and testing. But am unable to capture good quality in version 1.5.1.
I have killed any processes running in the background. But it doesn't seem possible to capture using this version and my setup...!!!
Canon DC230 New Ticking Sound On Playback
By cool4cats in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 7th Jan 2012, 07:23 -
Capture Settings / Weird lines in final product
By BooBerry in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 23Last Post: 26th Jan 2009, 11:14 -
Final product not satisfactory!
By ingeborgdot in forum Authoring (DVD)Replies: 14Last Post: 8th Sep 2008, 23:09 -
Final product from Vegas studio 8 plat. Too big
By Jensen in forum EditingReplies: 4Last Post: 17th Jan 2008, 19:23 -
Looking to buy a capture card or any other related product.
By jonathan3566 in forum Newbie / General discussionsReplies: 11Last Post: 7th Jul 2007, 01:10
