Hi when i open my .avi file in TMPGENC which is a divx movie, it says the avi is unsupported. I know its a compressed avi cause its divx. What should i do? Email swizzbeatz905@Yahoo.com
i get exactly the same prob m8.. a long time ago i used tmpg and it worked fine on every thing i converted but when i formated i didnt work at all ive got all the codecs but stil no luk unsupported just like u :( so i started using panasonic mpg encoder it works does the audio & vidio in 1 no uncompresing at all just put it in and way it goes but it takes longer than tmpg and some times the audio isnt in line with the video so its like its in japaness
AmArU SiGnInG Of OvEr AnD OuT
File .avi can't work on my new MP4 player
By jj_rouge in forum MacReplies: 14Last Post: 10th Aug 2024, 22:12 -
Avi file wont play when playing with .srt subtitle
By cudencuden in forum SubtitleReplies: 2Last Post: 25th Mar 2009, 20:40 -
Why wont subtitles work?
By .deathnet in forum SubtitleReplies: 2Last Post: 3rd Mar 2009, 12:01 -
Disc will/wont work between different DVD players.
By Scroogle in forum DVD & Blu-ray PlayersReplies: 3Last Post: 17th Jan 2008, 14:41
