Hi all!
I have converted 16 .mov files to .avi using "rad video tools" and now I would like to join these files into one file. But when I try to do this using videodub (and the guides found here) I get a error message saying "cannot append video segment... the video streams have different sampling rates"
The files are of the same type (are continuous, just cut in several files), same resolution etc and I used the same codect with exact same settings on all files (tried divx, xvid and x264. x264 had the best quality to size ratio) the only thing that seems to differ is the framerate (off by ~2 frames).
Is there any way to join or recompress these files to get just 1 .avi? Is it possible to make all the .mov files into just 1 .avi file in the first step?
Thanks for your help!
