Hi. I have seen those portable hdd with audio and video playback of all types of popular formats like DivX and mp3. From some of the screenshots of the bootup screen, it seems like they use the same type of firmware found in other similar dvd players. I was wondering whether there is a possible hack so that it can play rmvb files? It is kind of irritating to have to convert them to avi everytime. Although I'm not a programmer, it seems like if they use a similar firmware, then a hack of one device could work for the other devices too? I would really like to hear some responses regarding this because there is XBMC for the Xbox which runs basically everything and whether it is possible or not. Thanks.
Hacking the firmware isn't likely to help. The codecs needed to play the files are typically found in your player software, no the firmware. In the case of standalone players, there currently aren't any players that support rmvb. I suspect that is licensing issue and/or the fact that it isn't a popular format. That's the price you pay for using a proprietary format.
Google is your Friend -
Not true you pa king loser! Do your research!
http://www.houseofdap.com/index.php?act=viewProd&productId=40
__________________________________________________ ________
~Treikens
-joined for this post
Free program to copy Movie dvd`s to my portable hdd
By rob74 in forum DVD RippingReplies: 4Last Post: 5th May 2011, 16:14 -
Portable hdd player determining playback limits
By terramir in forum Portable VideoReplies: 2Last Post: 6th Sep 2009, 23:46 -
dvd players and portable hdd?
By mrjust in forum Newbie / General discussionsReplies: 5Last Post: 15th Apr 2009, 17:44 -
Slightly OT -- Power Supply for External USB HDD used with Portable Device
By GrayStrickland in forum Portable VideoReplies: 2Last Post: 25th Mar 2009, 15:50 -
Which portable HDD ???
By Dash1 in forum Newbie / General discussionsReplies: 7Last Post: 29th Apr 2008, 23:45
