how do i find out if my connection is a 512 or 256 connection?
I am in QLD Auatralia.
Use a test site. If your downloads max out at around 29 - 32KB then you have a 256 connection. 512 should be around double that download rate.
http://www.speedtest.net/
http://www.speakeasy.net/speedtest/Read my blog here.
http://myspeed.visualware.com/ ... a bit more accurate as to connection type's .
You'll probably get different speeds at different test sites.
Just checked mine now.....
Myspeed.Visualware...... 4 mbps
TestMy.net..................... 3.1 mbps
Speakeasy Atlanta......... 4.3 mbps
Speakeasy Chicago........ 4.8 mbps
PCPitstop....................... 1.7 mbps
Saturday my speed was 100 kbps because Time Warner pooped out again.
A man walked into his son's room and said..."Son, that will cause blindness."
The boy said, "Dad, I'm over here."
Help me find the right solution please.
By abeaty in forum Video ConversionReplies: 8Last Post: 7th May 2010, 23:12 -
find the name of this movie
By canadateck in forum Off topicReplies: 3Last Post: 22nd Jan 2010, 18:55 -
where to find firmware
By chuckman45 in forum DVD & Blu-ray WritersReplies: 1Last Post: 12th Dec 2008, 02:25 -
Where to find SUBSYNCH
By Wan Dat Ting in forum MacReplies: 3Last Post: 18th Jul 2008, 20:15 -
Cannot find subtitles
By vertical in forum Newbie / General discussionsReplies: 5Last Post: 3rd Jan 2008, 18:26
