I'm looking for a video card that will ouput to my LCD monitor and also my 780p LCD tv. I'm not a gamer. Is there anything I need to look for so it will work well with the tv?
	The bigger issue is your TV. Some TV's have restrictions on input type and resolution. You may want to check your TV manual to verify it allows connectivity to a PC. Google is your Friend
	I'm currently using the tv to display video from my laptop, so that isn't a problem.
  I need KVM switch help, re: DVI and D-Sub cards..By sdsumike619 in forum ComputerReplies: 4Last Post: 15th Dec 2010, 00:51
  Hardware advice, video card & monitor, DVI or VGA ??By Noahtuck in forum ComputerReplies: 7Last Post: 12th Jul 2009, 01:58
  Does these video cards support dual screens?By SingSing in forum Newbie / General discussionsReplies: 1Last Post: 28th Jan 2009, 20:36
  best silent graphic cards with hdmi+dvi out and hdcp supportBy deejay.2001 in forum ComputerReplies: 5Last Post: 13th Jan 2009, 15:01
  a question about dual monitor video cardsBy wingnut2003 in forum Newbie / General discussionsReplies: 2Last Post: 24th Nov 2007, 08:49
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
