    Oct 2006
    record videos from a another flashvideo website.
    The copy/pasted link looks like this:
    http://www.comedycentral.com/motherload/player.jhtml?ml_video=76641&ml_collection=&ml_...is_large=false
    Should I edit out and/or include something else in the link for it to work?
    Thanks a Trillion
    Spo
  2. Member zoobie's Avatar
    Feb 2005
    Florida
    It's running a script. You may be stuck with a screen cap
    Oct 2006
    Hey Thanks a ton for your quick reply
    Can you translate for a Technological Hillbilly like myself what you mean and if that makes it impossible to download?
    Thanks Again
  4. Member zoobie's Avatar
    Feb 2005
    Florida
    I means theres a separate script that it's posting to that then gets and displays the video.
    Search "screen capture" here or in tools for a solution
    Oct 2006
    Thanks for getting back to me. I guess what youre saying is that the screen capture tool is the one to use. I will check the guides and try to also consult a high school student.
    Thanks!
