sorry if this is answered elsewhere,i did do a search but no luck.
my question is on bitrate.for example,i have a 700mb avi file its encoded at roughly 730kbps,i usually stick that in nerovision (not to everyones taste i know,but i like it),crank the bitrate upto
6000kbps(ish) and get a 4 gig dvd video_ts folder.
if i were to set nero a lot lower on the bitrate,say,1000kbps and encode it and get a 1 gig dvd folder would there be any difference? or would it get all blocky etc?
thanks for any pointers on this.
cheers
jonx
It will get all blocky and look like crap. MPEG2 requires higher bitrate then avi with divx,xvid,mpeg4 codecs.
Generally, mpeg 2 requires at least 3 - 4 times the bitrate of mpeg4 (Xvid/Divx) or more (mpeg4 H264) to maintain similar quality. And this is without taking into account the resizing that needs to be done during conversion, and all the artifacts and blockiness in the source.
Read my blog here.
High Quality At Low Bitrate?
By sanosuke in forum Video ConversionReplies: 4Last Post: 4th Apr 2010, 08:21 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
How to reduce blocky artifacts in low res, low bitrate video
By The111 in forum Newbie / General discussionsReplies: 48Last Post: 20th Mar 2009, 18:29 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54 -
Divx Bitrate Adjustment - Low Motion or High Motion? TmpgEnc Xpress 4
By Sliztzan in forum Video ConversionReplies: 5Last Post: 31st Aug 2008, 20:11
