Hi there!
There is always warning message "AVIFileGetStream:No data:" when CCE250SP open a DV AVI[Type 1 DV AVI]file captured by Scenalyzer under Win2K & Win98, if use a crack patch for CCE250SP, CCE250SP always crach when opening under Win2K!
Any suggetion?
dude cce 2.50 dont work on win 2k or xp i have the same problem get 2.62 from some where i hear it work the best for 2k or xp
Thanks! but someone told me that only cce250 can only work with VDub frameserver for resizing, I've got a DV Avi file [720*576], i must resize them to 480*480 before CCE250SP encoding to SVCD
CCE262 can not work with frameserver from VDub!i've try,
any suggetion are appreciated!
Thanks -
what is
frameserver and how those that work and what program is need it for that ???
[/quote] -
http://www.vcdhelp.com/faq.htm#frameserveOriginally Posted by natcom
@Frank Yu, cce 2.5 can not convert DV type1. Easiest solution might be to convert DVtype1 to DV type2.
If you can not do that, do audio and video seperately.
Open the file in TMPG and encode the audio only.
The video frameserve with Avisynth to CCE using DirectShowSource.
DirectShowSource does not support audio.
[/code]
Error message when trying to encode one file using AVStoDVD Program
By spritely in forum Video ConversionReplies: 3Last Post: 25th May 2011, 11:52 -
RipBot error - DirectShowSource: couldn't open file
By sweetalmond in forum Blu-ray RippingReplies: 2Last Post: 20th May 2010, 22:42 -
error message when adding SSA. file to virtual dub
By fredsieg1937 in forum SubtitleReplies: 1Last Post: 24th Sep 2009, 20:53 -
DirectShowSource: Couldn't open MKV file ERROR?
By th3obr0 in forum Video ConversionReplies: 1Last Post: 9th Jun 2009, 05:53 -
Sub2Divx Runtime error 55, file already open.
By bizzybody in forum Newbie / General discussionsReplies: 0Last Post: 4th Apr 2009, 23:48
