I have an mpg file of a VHS video transferred to DVD via my set top recorder. Transferred it to the PC using DVD-RAM then renaming the file extension to mpg, and I want to add chapter menus, etc. I've done this many times before without problems. I use Tmpgenc Plus and the "Simple De-multiplex" option, then import the m2v and ac3's into Maestro for authoring.
On my latest project the final burned DVD has the audio very slightly out of synch. I've experimented in Media Player Classic and seems if I set the audio to around -100ms then it looks right. This seems to be constant through the whole disc. I've gone back and checked - it's out of synch on the Disc Navigator within Maestro, so it's a problem even prior to burning. The original mpg file is in synch, so by deduction it must be a de-multiplexing problem?
When I import the m2v & ac3 files into Maestro the audio is 2 frames longer than the corresponding video (am not sure if that's anything to do with the problem?). What's going on here and is there anything I can do? Do I need to try different de-multiplexing software?
I assume you meant the QuickStream Fix tool? This appears to have worked a treat - it's now in synch in the preview screen of Maestro. Brilliant, and thanks profusely, you may have saved me hours of fiddling and much torn-out hair!Originally Posted by Barnabas
audio and video not in synch by a second or two problem
By sabathiel in forum Capturing and VCRReplies: 0Last Post: 14th Oct 2011, 21:45 -
Need some help with a synch problem
By kotyczka in forum AudioReplies: 3Last Post: 10th Jul 2011, 07:26 -
Tovid Synch Problem
By Ogilvy in forum LinuxReplies: 4Last Post: 7th May 2010, 14:52 -
MTR-Toast Multiplex problem
By danielmak in forum MacReplies: 0Last Post: 20th Feb 2010, 10:31 -
Audio At strat in Synch , along of Movie Lost Synch with Video !!!!!
By p_samimi in forum AudioReplies: 9Last Post: 12th Jan 2008, 23:47
