    Jan 2007
    I used Handbrake to fit 4 movies into a dvd-r.
    I created the disc by dragging the 4 mpeg4 files from my hd to dvd-r.
    When I inserted the disc to my phillips 5960 it says disk unknown.
    I tried to put a smaller mp4 created by handbrake to a thumbdrive and it cannot see the mp4 file but it can see my other files like jpegs.
  2. Not what you want to hear but the DVP5960 will not read MP4 files, only AVI ones (DivX/Xvid/MP3/AC3).
    I have a 5960 as well and it plays everything I've ever compressed with Handbrake (and nigh on everything else I'd expect/hope it would)
    Apr 2005
    Blacksburg, VA USA
    If you want to play on a consumer DVD player, it has to be
    in the right format. Toast (7+) will happily do all that stuff
    for you.
    Al Bloom
    Jan 2007
    ffpooky,
    I encoded with avi and it works but it is very blocky when there are a lot of movements. I encoded using 1000kbps.
    Anybody knows how to do this right?
  5. Going with 2-pass encoding should certainly improve that situation and I favour a 1500kbps ave. bitrate. Conventional wisdom is that using ffmpeg as the encoder is quicker (definitely) but produces slightly lower quality results compared with xvid at the same bitrate (?).
    As I look at it, you're only encoding things once so it's worth the extra time with 2-pass/xvid
