Hi folks,
i want to convert an imovie mov file into an avi with ffmpex, the video works fine but im not able to convert the audio. when im playing the mov-file with quicktime there is sound, when i open it with ffmpex it finds the audio-line but after the converting there is no sound...
i add a screenshot to explain my problem:
heres the log:
Code:Encoding started on Sun Jan 28 12:38:02 CET 2007 MEncoder dev-CVS-060307-04:23-4.0.1 (C) 2000-2006 MPlayer Team Mac OSX static build for ffmpegX FIXME:Hardenabling SSE and SSE2 without detection CPU: Intel (Family: 6, Stepping: 8) CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1 Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2 success: format: 0 data: 0x0 - 0x2808fc50 ISO: File Type Major Brand: Original QuickTime Quicktime/MOV file format detected. VIDEO: [avc1] 784x576 24bpp 29.762 fps 0.0 kbps ( 0.0 kbyte/s) MOV: selected audio stream (1) does not exists [V] filefmt:7 fourcc:0x31637661 size:784x576 fps:29.76 ftime:=0.0336 Opening video filter: [expand osd=1] Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1 Opening video filter: [scale w=784 h=576] ========================================================================== Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264) ========================================================================== Forcing output fourcc to 58564944 [DIVX] VDec: vo config request - 784 x 576 (preferred colorspace: Planar YV12) VDec: using Planar YV12 as output csp (no 0) Movie-Aspect is undefined - no prescaling applied. SwScaler: using unscaled Planar YV12 -> Planar YV12 special converter videocodec: libavcodec (784x576 fourcc=58564944 [DIVX]) Writing header... ODML: Aspect information not (yet?) available or unspecified, not writing vprp header.
I'm having similar problems. Right now, I'm trying to process a video through ffmpegx in order to then datamosh in avidemux. I'm using the presets found here http://www.court13.com/datamoshkit.zip . The video is a .mov, and after being processed loses it's audio. Any help on this would be greatly appreciated.
help -No sound when converting .mov files
By bloke666 in forum ffmpegX general discussionReplies: 0Last Post: 11th Dec 2011, 11:48 -
Problems converting camera's MOV to FLV via ffmpegx
By ygg in forum MacReplies: 5Last Post: 13th Feb 2010, 22:27 -
Problem with converting MOV files from iMovie / Camera
By pred02 in forum Video ConversionReplies: 1Last Post: 23rd Sep 2009, 02:25 -
Converting (Quicktime) .MOV file to .WMV file
By stanislawski in forum Video ConversionReplies: 2Last Post: 6th Feb 2008, 18:19 -
Converting ripped VOB to a .mov WITH SOUND....
By elmo7082003 in forum MacReplies: 3Last Post: 9th Oct 2007, 23:52
