Hi,
I just converted an .avi file(1,36GB) into a dvd and I ended up with a folder(Avi2dvdtemp,459mb) containing this files:
AudioStream 1 AC3 6CH.ac3 (496.559kb)
DVD_Image.iso(846kb)
Avi2dvd_log
Avisynth_Script_File.avs
BeSplit.txt
Spumux.xml
And a folder named "DVD" containing this two folders: AUDIO_TS and VIDEO_TS
Those last two folders seem to be completely empty when I open them.
So here's my question: Will my dvd player just be able to play the movie when I burn the .iso file using alcohol 120% or is there something wrong with those last two folders and will my dvd player give an error? I have only one blanc dvd+2 left so I dont want to wast it...
Thanks in advance
Garvin
avi2dvd_log.txt
Closed Thread
No, 846 kb is too small, it should be several gigs if it worked correct. Try convert with something else like DVD Flick instead and see if it works better.
help please with AVI2DVD
By kayla33 in forum Video ConversionReplies: 5Last Post: 19th Feb 2011, 13:10 -
Avi2dvd
By sportflyer in forum Video ConversionReplies: 4Last Post: 18th Feb 2010, 00:15 -
Avi2dvd help
By morg55 in forum Video ConversionReplies: 3Last Post: 27th Mar 2008, 16:51 -
What Deinterlace does in Avi2Dvd?
By geek2330 in forum Newbie / General discussionsReplies: 2Last Post: 24th Jun 2007, 20:51 -
Avi2DVD
By geek2330 in forum Newbie / General discussionsReplies: 3Last Post: 21st Jun 2007, 13:53
