    Feb 2006
    Canada
    Hello all.
    I just did a quick test of my Sony DVD-R 16x DVDs after burning a DVD using about 96% of the disc's capacity.
    I'm testing using NERO CD-DVD Speed utility and I wanted to share my results with you as they don't seem to be very good (however, i'm not sure how to interpret my results because i have nothing to them compare to). Here they are:
    PI Errors:
    Average - 826.37
    Max - 1438
    PI Failures:
    Average - 106.64
    Max - 408
    Also, all tests were done at a 4x read speed.
    Thanks for taking the time to read this post, any input is appreciated.
    Feb 2006
    Canada
    Anyone??? Any ideas?
    Thanks.
    Feb 2004
    Pleasant Hill, CA
    Here's a quick-n-dirty explanation for interpreting results from DVDInfoPro (similar?) from the ImgBurn forum:
    http://forum.imgburn.com/index.php?showtopic=2168
    May give you a start.
    Jim
    Feb 2004
    Pleasant Hill, CA
    Here's another guide, focusing on Nero CD-DVD Speed, that I had bookmarked at home:
    http://www.bitburners.com/Guides/DVD-R_and_CD-R_Recording/DVD_Media_Testing_Guide_For_Newbies/
    That should help.
    Jim
  5. Member rkr1958's Avatar
    Feb 2002
    Huntsville, AL, USA
    Originally Posted by tarrickb
    PI Errors:
    Average - 826.37
    Max - 1438
    PI Failures:
    Average - 106.64
    Max - 408
    That scan indicates a horrible burn. I typically look for and get PI failures of max <= 4 and PI errors of average <= 10 and max <= 50.
    I'd have trouble playing a burnt disc in any of my standalone players with a scan that show. Have you tried playing yet?
    Feb 2006
    Canada
    First off,
    I want to thank all of you who replied.
    Now, it appears the results i was getting from my Lite-On burner were NOT accurate because i tried doing the test with my Pioneer drive and the test results were much better (i think the failures were about 4).
    i will update the firmware of my Lite-on drive and re-test.
