Greetings from Scotland
Just bought a NAPA DAV311 VCD/MP3 player. Been using VCD Galaxy to rip DVDs and create a supposedly VCD compliant mpg file.
The file plays fine using Windows Media player. However when I burn it on to CD (I've used both Nero 5.5 and Roxio Easy CD creator 5) the sound looks fine but the picture appears 'jumpy'. Its hard to explain the actual picture quality is fine it just appears to jump every few seconds.
The only clue I have is that when burning using Easy CD I get a warning message saying something about the pack size of the video stream might be a problem. Any ideas?
PS
I checked the PAL settings etc were correct. I also should say that I can play downloaded VCDs in my player. I don't know what else to look at. VCD galaxy is definitely making me 'stuttery' CDs
Kind regards
Cakey
Thanks for your message
I've tried burning at both 4x and even 2x and that makes no difference. Its something else. Anyone know of any other all in one utility I could use rather than VCD galaxy (can't be bothered with all the messing about with loads of bits of software and encoders).
CakeHole -
well....if you want flexibility, then u may have to use different proggies for different steps of the dvd ripping process..that's the best way to make sure nothing goes wrong
Rip audio from VCD
By miamicanes in forum AudioReplies: 9Last Post: 4th Aug 2010, 09:04 -
Rip by playing software?
By chiuchimu in forum DVD RippingReplies: 13Last Post: 22nd Jun 2010, 10:03 -
rip w FAB then reauthor w SHRINK --> very slow to start playing
By JohnnyBob in forum DVD RippingReplies: 6Last Post: 13th Jan 2009, 10:41 -
Playing VCD on Computer or convert to DVD
By corumz in forum Authoring (VCD/SVCD)Replies: 3Last Post: 22nd Jun 2008, 06:35 -
help rip vcd
By Mjzchild in forum Authoring (VCD/SVCD)Replies: 1Last Post: 28th Jun 2007, 03:39
