    Jan 2007
    The howto instructions on ffmpegX are a great idea, but they seem to alway suggest the use of Toast. Are there are free alternatives to toast for burning VCD and SVCD?
    Thanks,
    pottmi
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    SimplyBurns (freeware) burns bin/cue files (as generated for VCD). So do some other freeware and shareware packages.
    The multitrack img files generated for SVCD are a bit tougher to burn without Toast. But there are workarounds if you keep the .mpg file:
    GNU vcdtoolsX 1.1 could pack SVCD MPEG files in bin/cue format, but is officially no longer available. (Google has loads of dead links on this tool.)
    VCDGearX packs SVCD MPEG files in bin/cue format using the mpg2bin option.
  3. You've got VCD Builder too. It'a freeware and builds VCD and SVCD.
    http://homepage.mac.com/johan/vcd/vcd.html
    http://videoandco.chez-alice.fr (guides in french)
    Jan 2007
    I took a look at these and they might do the trick. I am starting out with some mp4 files. Do you have any specific suggestions?
    Thanks,
    pottmi
    Aug 2005
    Palo Alto, California USA
    You should be able to find detailed how-to guides in ffmpegX's documentation. A brief summary is:
    1) Use the (S)VCD presets.
    2) Run ffmpegx.
    3) Burn the resulting images onto CDR using the non-Toast programs mentioned by others. (Another free alternative is MissingMediaBurner).
    Jan 2007
    I checked version tracker and it seems that MissingMediaBurner seems to have stopped development. It does not run on tiger.
    I did find an alternative: burn
    http://burn-osx.sourceforge.net/
    Thanks,
    pottmi
