Hi all. i got 9 mpeg2 captured files and the total size is one geg. I want to make a dvd out of. Could any one tell me what is the fastest way to make simple dvd out of them. Does my mpeg2 files require conversion in process and how will be the speed of making dvd?I be happy if an expert help me here.Thanks
You must author it, https://www.videohelp.com/author#3;6 , easiest is tmpgenc dvd author. If you want something free try guifordvdauthor.
Thanks for u reply. I noticed that my pinnacle sudio 10 can make dvd but the problem is that it is rendering my files and it takes too long. May i know why it is rendering as the files are already in mpeg2 format? I was expecting that no rendering is involved since the files are in mpeg2 format already!! I be happy if put some light on this issue and let me know if there is any faster way to burn it to dvd.ThanksOriginally Posted by Baldrick
mpeg2 isn't the only requirement to qualify as DVD Video source material. Take a look under WHAT IS DVD top left for the specifications.Originally Posted by method
OTOH, I wouldn't trust an application that can reencode to author - many of this breed seems to blindly reencode by default, necessary or not. Try TDA or other dedicated authoring app previously suggested.
/Mats
Make Two MPEG2 Files Same Specs
By shagratt71 in forum Video ConversionReplies: 28Last Post: 20th Apr 2012, 06:31 -
Can't make DVD from files (even an image)
By Karstedt in forum Newbie / General discussionsReplies: 2Last Post: 26th Dec 2010, 17:03 -
divx files how to make a dvd with this
By sumeshkri in forum Authoring (DVD)Replies: 9Last Post: 23rd Sep 2008, 08:04 -
Make a DVD from VOB files
By jmsrickland in forum Newbie / General discussionsReplies: 5Last Post: 6th Aug 2008, 20:30 -
How to burn .ts files to make a DVD ?
By comag in forum Newbie / General discussionsReplies: 3Last Post: 13th Jul 2007, 14:28
