I have an avi file that has a sectoin of 17 bad frames in the middle. I was able to cut the frames out with Virtual Dub, then saved the file as avi with Direct Streaming for both audio and video. Everything is fine until the are where the frames were removed, then the audio is off? Can someone help me get this corrected?
Results 1 to 1 of 1
VirtualDub - fixing bad frames with blending and without re-encoding
By spicediver10191 in forum Video ConversionReplies: 3Last Post: 11th Apr 2012, 08:15 -
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 22:33 -
Removing Weighted Prediction in P-frames
By ad.vid in forum Blu-ray RippingReplies: 4Last Post: 29th Oct 2010, 12:18 -
.avi file cannot be repaired - need to remove bad/corrupt frames
By realtechtalk in forum Video ConversionReplies: 0Last Post: 7th Sep 2008, 12:27 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 20:59
