I just purchased a new ATI Radeon X1300 card about 2 weeks ago,and let me tell you it works GREAT.It supports the AVIVO codec with it,also came with the card.My question about AVIVO is what exactly does it do,basically what is the full details on it.
P.S.
Im having NO problems with the card,just wanted to no a little info about the AVIVO codec from ATI.
Here is a direct link if any wants to know what im talkin about........
http://ati.amd.com/technology/avivo/index.html
From what I recall, aside from all the info on the link you provided, it is basically there answer to providing a HD output to your display. For normal pc use it is of no major consequence. It is intended primarily for HTPC use and for HD output to a TV/video display.
Google is your Friend -
Go to http://www.anandtech.com/ and search for AVIVO. They have many articles about it. For example:
http://www.anandtech.com/showdoc.aspx?i=2551
http://www.anandtech.com/showdoc.aspx?i=2536
Also, TomsHardware.com:
http://www.tomshardware.com/2007/01/09/avivo-vs-purevideo/
Anyone Have Experience Converting MPEG2 to H.264 with an ATI Avivo Card?
By drstew in forum Video ConversionReplies: 3Last Post: 24th Jun 2010, 10:00 -
MPEG2 files of VOB2MPG not accepted by ATI AVIVO video converter
By 33M344 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 13th May 2010, 13:53 -
ATI AVIVO
By therock003 in forum Capturing and VCRReplies: 18Last Post: 28th Jan 2009, 18:31 -
AVIVO Confusion
By jameson_uk in forum Software PlayingReplies: 2Last Post: 11th Sep 2008, 17:44 -
Purevideo or AVIVO?
By rhythminmind in forum Newbie / General discussionsReplies: 2Last Post: 12th Oct 2007, 14:13
