I just built a new rig for my mother. When I insert a pen drive, it works fine. But when I go to safely remove it, the CPU usage hits 100% and everything crawls. Any idea what would cause this?
Details on the PC are in this topic.
https://forum.videohelp.com/viewtopic.php?t=319491
Edit:
I now know it has something to do with Diskeeper. THe problem stops when I disable the service. I've never had this issue with DK before. Any input it helpful.
Maybe dump Diskeeper? Unless they have a fix and if the problem is really caused by the program, why use it? If you are using it primarily for defragging with XP, is fragmentation a big problem? JMO, but I rarely defrag.
Oddly I enabled automatic disk detection in it, which I usually don't since it plays hell with Pen Drives. Then I disabled it again and it seems to be working fine now. I hope it lasts.
Restoring "Safe To Remove Hardware" Popup Confirmation
By CobraPilot in forum ComputerReplies: 8Last Post: 3rd Jan 2012, 12:35 -
How Do I Store Video Files Safely Forever?
By Video-Guy in forum Capturing and VCRReplies: 32Last Post: 5th Feb 2011, 17:52 -
How to safely add user data folder to DVD Video?
By fvisagie in forum Authoring (DVD)Replies: 3Last Post: 1st Oct 2008, 06:32 -
Capture Locks on the first
By depsci in forum Newbie / General discussionsReplies: 4Last Post: 2nd May 2008, 14:21 -
Is there a program that can safely convert variable frame rate videos?
By darkzero297 in forum Video ConversionReplies: 1Last Post: 17th Jul 2007, 20:01
