Error appear like this " An out-of-bounds memory access (access violation) occurred in module 'ntdll'."
I can't edit video at all, because it crash often. what should I do?? I downloaded bug fix , but still there is problem
I rarely see VirtualDUbMod crash. When it does it's usually because of a mangled source file -- and the crash is usually caused by the codec that's uncompressing the video. There are a few buggy filters that can cause crashes.
Does your problem occur with all source files? If so, your system may be overheating. -
I have this problem too. I use AutoGK which has VirtualDubMod in the package. When I want to add subs onto a video and also compress the video. It worked the first 2 times. But then, after a weeks later. I wanted to do the same thing with another video, but VirtualDubMod crashes some reason. I then thought was it to do with the video, so I tried with the previous videos which worked, but it turned out to be the same result. I'm not sure if there has been something corrupted but I haven't touched the program since it was last workable.
Try this : http://paul.glagla.free.fr/filmerit_en.htm to check for directshow filter error's (read the page on how to use it) .
Dont forget to use gspot after this problem appear's (preferably before hand)... you may need other filters installed first ...
Then hijackthis , scan system , disable all non-essential startup program's , let if fix those checked and reboot , and retest once more for the apperance of crash .
Check for updated vga driver's .
Run memtest or the ms version http://oca.microsoft.com/en/windiag.asp
It's also worth while installing avgfree , update , and scan the whole system for any lurking problem's ... remember to empty the vault after ... to remove some , you need to disbale system restore , rescan , empty vault ... reboot pc , reset system restore .
Do a scan disk , and a defrag as well . -
There was no message but I knew. Normally, when I first used the program it worked. I have a dock to see my computer performance when working. The first time, when I starting dubbing, my CPU usage would go to 100%. But now, when I start the program, it doesn't even change my CPU usage so I went into Task Manager to check it out and it always says VirtualDubMod is not responding. AutoGK seems fine but it's just VirtualDubMod which crashes.Originally Posted by jagabo
VirtualDubMOD crash
By BlundaKat in forum Video ConversionReplies: 4Last Post: 28th Sep 2009, 09:17 -
VirtualDubMod Access Violation Crash
By k3yword. in forum EditingReplies: 1Last Post: 29th Jul 2008, 20:19 -
vdubmod crash
By RobMan in forum SubtitleReplies: 4Last Post: 31st Dec 2007, 09:22 -
Pinncle Studio 9.4.3 worked just fine, now CRASH CRASH CRASH
By maxtrack in forum Newbie / General discussionsReplies: 18Last Post: 11th Sep 2007, 01:38 -
VirtualDubMod crash!
By fruitpassion in forum Video ConversionReplies: 0Last Post: 1st Aug 2007, 15:06
