    Jan 2007
    When ripping a wav file using AoA Ripper from my Camcorder mini DVD it refers to the sound file as" ???AC3 2ch (0x80)". Even after editing in Audacity I can't seem to get rid of a buzzing effect on my speakers (similar to a blown speaker cone). Can this type of sound file be repaired in any application you guys know of?
    Hope you can help.
    Thank you.
    Gangly1
    USA
    I would try a different program to extract the audio to see it that helps. If the audio is AC3 on the DVD, I wouldn't convert it anyway unless you need to edit it.
    You could try VirtualDub Mod and the AC3 ACM Decompressor if you want to convert it to WAV. I would use full audio processing to extract to WAV.
    There is one program you might try for repair, but it may not help for that, AC3fix GUI and AC3fix.
  3. Member Soopafresh's Avatar
    Jan 2004
    If you can open it in Audacity, you must have converted the file to WAV, yes ?
    Jan 2007
    Thanks Red and Soop.
    I used a different program to extract the AC3 audio and it works fine.
    Gangly1
