Ok this is what ive learned so far.
Xbox can read most CD-RW's. It can read a Few CD-R's
Sence it can read Dvd's I figured it had the MPEG-2 drivers in there somewhere. With that in mind I did the following.
I used TMGENC to encode a DVD movie file roughly 20 seconds long.
I then burned the file to a CD-RW(Memorex 74min) using Ulead DVD Movie Factory.
I Put the disk into the xbox and the playback was all Jumpy and there were green blocks everywhere. I guess alittle success is better then no success right?
Sence it is all Jumpy I figured the birate is to high. The Bitrate for a DVD compliant movie is maxed at 9000 I believe. Correct me if im wrong.
Is there anyway to lower the bitrate and still be a DVD compliant video? I tried lowering the bitrate but then Ulead wouldnt except the file saying something like the file wasnt compliant.
Is there a programe out there tha maybe warns u that the file isnt compliant but still lets you burn it? Sorta like Easy Cd creator?(Easy cd creator doesnt let you burn dvd files right?)
Thx for any reply's
I see no option to burn a dvd file in nero. All I see are the VCd and SVCD options.
This is true for the latest Nero Under "File" select preferences. On the expert tab there is a checkbox for "Show all compilation types..." This activates a dropbox in the "New Compilation" window where you can choose DVD
I suspect that this may not be the problem...
The Xbox probably has the same hardware limitation that most standalone DVD players have: They can read CD-R, they can read DVD, they can read VCD or SVCD material off a CD-R, and DVD material off a DVD disk, but they don't comprehend DVD material off a CD-R (which is miniDVD format).
As far as bitrates for DVD, I don't believe it's much of an issue, as much as the video size, and format. Pretty much anything goes for DVD bitrate, and the allowable specs are:
MPEG-2, 525/60 (NTSC): 720x480, 704x480, 352x480
MPEG-2, 625/50 (PAL): 720x576, 704x576, 352x576
MPEG-1, 525/60 (NTSC): 352x240
MPEG-1, 625/50 (PAL): 352x288
I don't believe that the Playstation 2 plays miniDVD either, so probably the same goes for the Xbox. -
The Xbox
Can not read CD-R's(except a few brands)
It can read CD-RW
I did have a little success at the 1st atempt but thats it.
Help capturing xbox 360 video when xbox is connected to monitor with vga
By laldabomb8 in forum Capturing and VCRReplies: 0Last Post: 23rd Jul 2010, 02:05 -
Need additional info about re-encoding Blu-Ray
By snipingkid in forum Blu-ray RippingReplies: 7Last Post: 23rd Apr 2009, 13:12 -
Total noob needs help encoding from Xbox 360 footage
By FreeBaGeL in forum Newbie / General discussionsReplies: 0Last Post: 17th Feb 2008, 14:27 -
Encoding from Vegas Video 8 to XBOX
By tobyjordan in forum Video ConversionReplies: 1Last Post: 10th Dec 2007, 12:36 -
How to find encoding info of a Flash video (.flv) file?
By Netozai in forum Newbie / General discussionsReplies: 2Last Post: 9th Oct 2007, 14:35
