Hi..i am a total newbie about dvd and vcd..i have a vcd movie..which i copied to my system and is in .dat format.. so i need to copy it into a new dvd.. using nero express..
is it possible to create a dvd using nero..???i mean do i have to convert .dat file into any format??
how do i do that?? and ther is no option in nero for video dvd.. it has option only for data ..so is it possible to copy this .dat file to dvd ???
please give a solution
thnx in advance
I have had trouble with .dat vcd files as sometimes there are confused with system files. Do you have nero vision express that is the nero software to make dvds. Nero express can make a vcd, but better to use vision express. How did you copy vcd to system and get it in .dat format? I don't know how to get .dat vcd format to record to disc. Someway to convert that to a video file is a suggestion. Can you playback that .dat file? Do you know of another way to get on your computer but as a video file like .avi?
Simple enough. The easy way is to use TMPGEnc DVD Author. It will automatically convert the 44.1Khz audio to the 48Khz standard DVD audio rate and burn it. VCD video is already DVD compliant, just the audio is wrong. Easy is to rename the .dat files to .mpg and convert the audio.
If you look to the upper left on our site for 'WHAT IS' DVD, you will see the DVD format and specifications. <<<<<<
You can try Nero after renaming the .dat and converting the audio, but I'd be suprised if Nero does it without messing it up. Nero is OK for burning, but not much else, IMO.
And welcome to our forums.
why can't I make dvd w several half hour shows dvd architect/sonic-
By rr1 in forum Newbie / General discussionsReplies: 5Last Post: 14th May 2011, 13:28 -
Ulead DVD MovieFactory 6 prob w/using 3.7GB mpg to make DVD
By GSP_87 in forum Authoring (DVD)Replies: 4Last Post: 6th Nov 2009, 05:05 -
How to make such DVD?
By Remyisme in forum Newbie / General discussionsReplies: 9Last Post: 27th Jul 2009, 20:57 -
Best software (pref freeware) to make a music DVD that will play in a DVD
By Trollheart in forum AudioReplies: 10Last Post: 16th Jul 2009, 16:12 -
How do I make my Samsung R150 recorder region free? I have the code to make
By charpee in forum DVD & Blu-ray RecordersReplies: 2Last Post: 26th Jan 2008, 07:10
