    Jan 2007
    Im having a problem viewing my co-workers Camtasia files... is there a way to convert it to QT or does anyone know of a codec that might be helpful in this situation.
    What video and audio codec in the video files? Identify with latest gspot or mediainfo.
  3. Member Soopafresh's Avatar
    Jan 2004
    I think Camtasia uses TSCC , the Techsmith VFW codec, so the process to convert would be similar to converting Xvid to Quicktime. If he has enough disk space, save the file as uncompressed video in Virtualdub, then use MpegStreamClip to convert to Quicktime. Procoder can do the conversion directly, but it isn't free.
  4. Member Cornucopia's Avatar
    IIRC, Techsmith has a QT decoder component for use with Camtasia->QT conversions called "Ensharpen". Seems to have QT for Mac, not sure about QT for PC.
