I've been able to successfully burn several DVDs (SmartRipper, pulling out the audio, ReMPEG2, and using DVDit to recombine everything onto a DVD).
I have a few DVDs, though, that I only want to keep a few chapters from, apiece. I'd like to merge them into one compilation DVD.
I know how to rip all the files, extract the audio, extract the MPEG2, and use the authoring tool to recombine everything and burn a DVD.
That seems like such a waste, though. I want to keep the original VOB files exactly as they're ripped. Is there a way to manually create the necessary IFO file to link all those disparate VOBs, and simply burn them?
Or is there an authoring tool that will work directly with VOBs? DVDit wants an MPEG2 and a WAV, for example, and it makes the VOB. I'm not interested in doing anything with the streams inside the VOBs, I just want to recombine a bunch of them onto a compilation DVD.
Thanks!
Check out the guides on http://www.doom9.net using IfoEdit. Should help you in some way.
Can anyone be nice to tell me where i can get the program ReMpeg2.
thanks so much
Can IFO-Edit merge files?
By Djard in forum Newbie / General discussionsReplies: 3Last Post: 15th Aug 2011, 10:50 -
How can I create IFO + BUP files for a VOB file?
By mac&me in forum MacReplies: 3Last Post: 4th Dec 2010, 02:06 -
Can I create an .IFO file from .VOB files?
By Madcap in forum DVD RippingReplies: 7Last Post: 15th Aug 2010, 14:57 -
How do I create VIDEO_TS IFO from VOB files
By stockton209 in forum DVD RippingReplies: 2Last Post: 8th Jan 2010, 03:07 -
how do i create ifo etc files
By gurunutkins in forum Newbie / General discussionsReplies: 3Last Post: 16th Nov 2007, 11:41
