Hello Friends,
I have Desktop computer without S-Video output. I want to connect my PC to TV to watch streaming movies.
Can you please suggest which video card to buy for S-Video output.
I have searched and found the one below. Will it suffice my requirement?
http://www.geeks.com/details.asp?invtid=SAA7130&AID=10440852&CJPID=1260291
Thanks in advance.
Unfortunately the card you referenced will not allow you to send computer based streaming video to a TV. It is a "TV card", which allows a computer to play and record TV shows. You'll need to buy a graphics card that has a TV out. Fortunately they can be had for not too much money, such as this one: http://www.newegg.com/Product/Product.asp?Item=N82E16814102447. You'll definately want to get a card that is specific to the graphics card slot in your computer's mother board (if it has one: your user manual should have info on this; the card I linked to does not need a graphics card slot). Also, you'll want to connect your computer monitor to this card, it will most likely provide a much better display than your computer's integrated graphics.
Something else to consider is that the picture quality of that streaming video may be somewhat poor, even when viewed on a TV. Good Luck.
Edit:
I forgot audio: the graphics card only does the picture and not the sound. You can either use your computer for sound, or connect an audio cable from your computer's audio line-out to your TV's audio-in so your TV plays the audio.Usually long gone and forgotten -
Hi,
Thank you very much for your details. I am new to this, so not aware of Video cards.
Based on your suggestions, I checked and found the following one with 256MB memory. (is it adv to have more video memory)
http://www.geeks.com/details.asp?invtid=R37L-SB3-WB
Thanks. -
That card is perfect for what you want if you're absolutely sure that your computer's motherboard has a PCIe graphics card slot. The graphics card memory is only useful for computer games such as the Sims (which BTW will play acceptably well with that card); for video playback it really has no impact.
Need Video card suggestion and terminology help (solved)
By gll99 in forum ComputerReplies: 9Last Post: 14th Aug 2011, 03:21 -
Suggestion to make the video look better?!
By SB4 in forum RestorationReplies: 11Last Post: 18th Sep 2010, 20:14 -
Filter suggestion for old video restoration
By the_provider in forum RestorationReplies: 11Last Post: 27th Apr 2010, 18:02 -
Suggestion for video decompiler...
By Starkian in forum EditingReplies: 2Last Post: 24th Aug 2008, 06:29 -
suggestion for vhs capture card
By abbymat in forum Capturing and VCRReplies: 8Last Post: 28th Jul 2007, 01:57
