I just made my first svcd with nero using the guide off this site. But when i try to play the svcd with powerdvd, it says unsupported format type. So now i have to switch to file mode and manually select the file in the MPEG2 folder, is this normal? Also what file extension should the AVSEQ01 be on the svcd? Mine is .mpg
Thanks.
it could just be your drive that does not support playing svcd
as i have 2 drives in one pc the svcd that i have will play in one np
but the other i have to use the method you talked about
Quick Question
By TagFan in forum DVB / IPTVReplies: 3Last Post: 26th Sep 2011, 09:45 -
Quick question about mkvextractgui
By draco_nite in forum Video ConversionReplies: 9Last Post: 7th Aug 2009, 18:41 -
Quick AVIdemux question!
By janlafata in forum EditingReplies: 16Last Post: 17th Mar 2009, 01:19 -
quick question?
By JRSWIFEY2004 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jan 2008, 16:38 -
Quick Question
By Scryer_360 in forum Newbie / General discussionsReplies: 3Last Post: 26th Dec 2007, 07:21
