Hi,
I'm following the VCD to DVD guides, and am having a problem with TMPGEnc accepting
the newly converted MPG file. As per the guide it says you may receive an error message
but just ignore this. However, the error message I am receiving casnnot be bypassed.
The error reads:
Cannot apply smart-rendering on this file.
Could not find the necessary information to process this file with smart rendering.
It is possibly an MPEG-1 with variable bitrate. This format does not contain the maximum bitrate information needed for the smart render function.
So I cannot continue. I have tried two different DAT movies the I have used ISO Buster to convert to MPG but I get the same error on both.
Can you help?
Thanks.
Well, it could actually be VBR video - which is not really a valid for VCD, but may have been authored as VCD anyway. Not sure how to fix this without reencoding, but youi could try remultiplexing the mpg using TMPGEnc (the encoder, not DVD Author).
/Mats
TMPGEnc DVD Author Error - Video Bitrate too high
By powerkoala in forum Authoring (DVD)Replies: 9Last Post: 22nd Nov 2008, 11:16 -
Error message in TMPGEnc 3 with Divx Authoring...
By blasedeviant in forum Newbie / General discussionsReplies: 5Last Post: 22nd Apr 2008, 13:29 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 16:28 -
TMPGenc DVD Author 3 issues "No stream available" Error Code 0x80
By newsletters in forum Video ConversionReplies: 0Last Post: 8th Oct 2007, 17:20 -
Strange error message when re-authoring with TMPEGEnc DVD Author 1.6...
By justin81 in forum Authoring (DVD)Replies: 3Last Post: 24th Sep 2007, 01:23
