Hello.
I recently discovered a big problem with several DVD's I encoded recently. The problem is the picture in some videos seem to be "lagging", not all the time, but when it does, you can really see it. I have tried the DVd on different players, but the problem remains the same. (On computer DVD player though I don't experience the problem). I have been recorded the DVD using VirtualVCR (for capture), converted to mpeg with TMPEGENC and used DVDLab Pro to finally encode the DVD.
I have no idea what might have happened during this process, but if anyone recognize or know this problem, please let me know. I have been trying myself to solve this without any positive result.
Results 1 to 13 of 13
jmaymeGuest
jmaymeGuest
Well, I aint sure if the word "lagging" is very fit, but when you watch the parts where this problem occurs, the frames looks like they are either missing or are playing twice. The picture is like, "hacking" (?). However it doesn't look natural when playing.
If you deinterlace, motion resolution drops from 59.94 field per sercond time slices to 29.97 frames per second. You will see film like studder in areas with motion.
Correction: For Sweden, 50 fields per second becomes 25 frames per second. -
Wrong field order will give a vertical jump during motion.
jmaymeGuest
Okay, seem like the possible cause has been found. When I choosed bottom field on all videos on a dvd, the picture "lagged", but with top field it didn't. I have memories of it setting some of the videos automatically to bottom field, so I suppose that is what caused it. Wish there were any way in correcting those afterwards though. Cost me a dvd but I guess it will spare me a lot of trouble.
Restream can change the field order without re-encoding, but you have ot demux the video to do it. Don't know if DVD Patcher can alter the field order inside a VOB.
Read my blog here.
Just make sure before encoding what the filed dominance settings are for the codec your using. Which codec were you editing/exporting ?
jmaymeGuest
I am not very sure, but I think it is Divx codec I have been using. It gave me the most of the picture, haven't seen any flaws or anything in it so far.
Originally Posted by guns1inger
Process a MP4 (Quicktime) in a "smart rendering" way. Not to be re-encoded
By whenloverageswild in forum Authoring (Blu-ray)Replies: 1Last Post: 19th Mar 2012, 09:53 -
"Live" picture effect - pictures end up "filmized"
By ANOther1676 in forum Software PlayingReplies: 10Last Post: 14th Oct 2011, 11:59 -
WMV "Encoded date" metadata, a mystery?
By Gew in forum Newbie / General discussionsReplies: 5Last Post: 22nd Mar 2010, 19:58 -
AutoGK question: Can I "Force IVTC" on "Hard-encoded NTSC&am
By BozQ in forum DVD RippingReplies: 11Last Post: 12th Jun 2009, 13:46 -
Black and white picture on NTSC television from "region free" DVD
By psears in forum Newbie / General discussionsReplies: 4Last Post: 13th Mar 2008, 13:00
