Results 1 to 11 of 11
  1. Hi
    Any way to mask bad frames in a mpg1 file, because i dont want to cut it out.
    Apr 2004
    Miskatonic U
    Not without re-encoding. Simpler to cut it in an mpeg editor.
    Read my blog here.
  3. That part i need is important,
    Feb 2004
    Australia
    You would need to be clearer as to what you mean as "bad" frame's in order for any advice to be specific to the current request .
  5. After a 30 odd min it starts pixelizing and the sound starts splurting. when i put it through tda i get divided by 0 errors. when i encode it through tmpgenc the whole movie gets pixelized.
  6. The Old One SatStorm's Avatar
    Hellas (Greece), E.U.
    Frameserve and encode. If that doesn't fix it, you are doomed. You can only cut the bad frames manually and adjust the audio on the later part.
  7. i have only done avi file frameserving using dvd2avi, hw do i do mpg?.
  8. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    If you load it into virtualdubmpeg2, what happens ? If it loads, you could cut out the section that's broken, replace it with a short clip of the same length made from black frames, and frameserve it to an encoder to re-encode. You might have to demux the audio first, then add it back in later.
    Read my blog here.
  9. Originally Posted by guns1inger
    i get errors saying "MPEG: Anachronistic or discontinuous timestamp found in video stream 0 at byte position bla bla and the when i press ok i notice that its only opned the good part of the movie, rest doesnt appear.
  10. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    The clip is screwed. Get a new copy.
    Read my blog here.
  11. The Old One SatStorm's Avatar
    load your file to mpeg2vcr. Cut the file to the "good part", pass the broken frames and save separate the second part.
