I have Mac quick silver tower(littleold) that runs OS X right now.(no dvd driver)
I have external dvd rewriter[ LG GSA-5163D] that I use for PC.
Q. I just put it to my old mac thru USB, but WHAT do I do to make my mac to read the driver??
anybody? :(
You don't want to use a USB drive with a Mac that only has USB 1.1 speed. With that connection the fastest you could burn a CD-R is 4X and the burning of a DVD would be so slow I don't think it would actually burn.
If you have installed a USB 2 PCI card in your Mac then you may have a chance of getting this to work. Go to www.patchburn.de and download the version of Patchburn that works with your OS version. -
Cost of a decent usb 2.0 card from OWC = $28
Cost of a new Pioneer 110D drive through newegg.com=$32
Why spend $28 on trying to get something to work when you could spend $4 more and get it right the first time?
(you'll use Patchburn either way, but.....
"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
There are no 110D's there. They have 111D's.Originally Posted by terryj
I had to check because the last time I tried to buy a 110D I had to buy on ebay. I ended up getting 3. Sold one to twosocks and kept the other two. I put one in a case and the other one is still in the box for safe keeping. -
lawn,
sorry about that.
Still, he could easily put in a -111 and get "MOST"
of his burning done, better than trying to hack
it USB wise."Everyone has to learn, so that they can one day teach."
Urban Mac User -
Momomoc also could take the LG drive out of its case and put it inside his Mac. But it would be smart to first update its firmware (if needed) while its connected to a PC.
Your recommendation to buy a new disc burner probably is best.
External Blu-Ray Player Software for Mac
By mrinternet in forum MacReplies: 29Last Post: 26th Nov 2012, 15:44 -
Yet Another What Burner Should I Buy . . . but for MAC-External
By Doctor X in forum DVD & Blu-ray WritersReplies: 11Last Post: 17th Apr 2010, 05:08 -
Raid 1 Firewire external drive, need to use on Mac AND Windows 7
By apollo1980 in forum Newbie / General discussionsReplies: 6Last Post: 19th Jan 2010, 15:00 -
Attaching a Mac External HD to a PC to copy
By phase52001 in forum MacReplies: 6Last Post: 21st Jul 2009, 05:49 -
my dvd-lo that works on Mac, not in external player
By oldblues in forum ffmpegX general discussionReplies: 8Last Post: 11th Jul 2007, 04:22
