Was googling around the other day and came across this "new" tool.
Switch Sound File Conversion Software
According to the website:
It also has an interesting "toolbox" which allows download / integration of additional freebies for such tasks as tone generation, editing, guitar tuning, CD ripping / burning etc.Switch Sound File Conversion Software
Audio File Converter.
Switch sound file conversion software is an audio file format converter for Windows or Mac. It can convert audio files from many different file formats into mp3 or wav files including wav to mp3, mp3 to wav, wma to mp3 and much more (see the supported formats list below).
Switch audio file converter is very easy to use. Just add the files you want to convert to the list, select the format you want to use, and then click the convert button.
It is probably well worth a look by someone with a more critical eye than myself before adding it to the tools section.
Results 1 to 1 of 1
How to delete/switch default language in a MKV file
By gquiring in forum Newbie / General discussionsReplies: 5Last Post: 27th Feb 2015, 19:35 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Conversion from VOB-File into a MP4 File stopps after 9 minutes...
By Fly Eagle in forum ffmpegX general discussionReplies: 2Last Post: 6th Aug 2009, 11:41 -
conversion software
By TigerWalkGuy in forum Video ConversionReplies: 3Last Post: 28th Jul 2008, 15:05 -
display problem switch from pc to tv, can't switch back
By samiam5156 in forum ComputerReplies: 1Last Post: 11th Oct 2007, 09:23
