Hello
After years of reading this site, tinkering and false starts I recently upgraded my computer finally to start editing various old Hi8 tapes. It seems the motherboard doesn't recognise my old ATI AIW 8500DV, so looks like it's time to get a new capture device. What are my options?
1. I can get a new capture card. I had been intending to capture in Huffy for editing purposes. Do I want to buy a new (AGP) graphics card that can do uncompressed Huffy capture? Or just buy a new cheap AGP graphics card and a dedicated PCI capture card? Any recommendations for that? - it seems difficult to find a recommendation for .avi capture.
2. I buy something like the Canopus ADVC55
http://www.canopus.com/products/ADVC55/index.php
These things seem to be highly regarded here. It seems that, although compressed, DV format is (obviously?) good enough to edit from - because the frames themselves are compressed individually, like a stream of JPEGs, is that right?
3. So a Firewire device like that would serve me well, except that if I ever want to buy a camcorder, I could instead put the price of the Canopus towards that. Will one of these do the same job?
http://www.canon.co.uk/For_Home/Product_Finder/Camcorders/Digital/mvx460/index.asp?Com...PageID=26346#1
So I'm leaning towards 3, unless someone can recommend a capture card. Have I got all that right?
Thanks everyone
Robert
Results 1 to 9 of 9
Since I am a relative newbie, I may be off the wall here, so don't laugh too hard if I have some of this wrong. You have analog camcorder tapes you want to capture, and then what do you want to do with them? Burn to DVD disks for family archive, Author, etc.?? If the above is true, do you presently have an analog camcorder that will play them?
Oh, sorry. Yes, I want to capture Hi8 (and some VHS) - holiday videos for example - and then I want to edit and archive it all. Output format? DVD, I suppose, or just leave it on the computer.
I've got an old Hi8 camcorder that will just about play the tapes long enough to capture the footage.
Robert -
The Canon MVX460 seems to have the analog to DV pass through feature so should do what you want. Ignor all the NTSC black level discussions. PAL works fine.
Use a DV format native editor/DVD authoring program and you are ready to go.
A simple program for capture over IEEE-1394 is WinDV. -
Well, I like the option #3 route myself, so I'll second that line of thinking.
I'm in the US, and have a JVC DV camcorder that serves me very well as a passthrough for my Beta and VHS stuff I'm slowly (too slowly!) transferring to DVD. As for quality, if you use a good encoder (I like mediaconcept myself) and don't try to fit too much on a single DVD, I can consistently turn out DVDs that look just like my tape footage. I'm sure my eye is missing something in there but for practical purposes, I'm happy.
True, you do have to pay attention to IRE levels (can be very confusing to figure this one out), but the guides here will help you do things right [blatant plug: edDV has a thread in here somewhere that talks about seeing levels in Premiere that I printed out and keep by my computer whenever I'm working on a project].
Good luck and have fun! -
Okay, you don't even have to worry about that!Originally Posted by edDV
I don't know how I would have ever survived making my first video if not for everybody at this site.
I am doing the same thing right now with old analog camcorder tapes. This forum recommended the Hauppauge 250PVR video capture card, and use the (free) Win TV2000 capture software from Hauppauge with it. Works a charm. Creates high quality mpeg2 files, and after that skys' the limit as to what you want to do. I personally use Pinnacle 10.7, and if set up properly works terrific on my computer, but other editors will import and work with mpeg2 files perfectly as well. Many don't like Pinnacle, but it works a treat for me. I am sure that there are other, lower-cost editors that will work. The Hauppauge card came with Ulead 5.0 (or was it 3.0??), but I wanted an editor that was newer with more power. After that you can burn to your DVD from your editor. Stay away from Nero, the quality just is not there at all. Hope this helps a bit.
For those using NTSC DV cams, this link describes the issues. The results can be excellent.Originally Posted by ozymango
"NTSC IRE levels and DV camcorder Pass-Through capture".
https://forum.videohelp.com/viewtopic.php?t=319733
Maybe this could be made a sticky?
VirtualDub Analogue Video Capturing Problems
By Dr Gonzo in forum Capturing and VCRReplies: 17Last Post: 22nd Sep 2011, 11:27 -
Help with capturing/editing needed
By Nilfennasion in forum MacReplies: 2Last Post: 24th Aug 2010, 12:25 -
Capturing DV - Editing with Virtualdub
By LSchafroth in forum Capturing and VCRReplies: 5Last Post: 27th Nov 2009, 21:19 -
Capture analogue (eg. VHS, analogue camcorder) - AVI or MPEG?
By ManUtdFans in forum Capturing and VCRReplies: 3Last Post: 18th Jan 2009, 19:29 -
Capturing analogue under vista Sound twice as fast as video
By djain91 in forum Capturing and VCRReplies: 1Last Post: 11th Jul 2008, 18:36
