I've been trying to capture some old VHS tapes to DVD and I'm having an issue with the sound. I was originally capturing them through QuickTV, the software that came with the capture card. I then moved on to VirtualDubMod. Whenever I try to watch the video, either through QuickTV or VDM, they play fine. However when I try to capture them, the captured files have no sound.
I've checked the capture settings in VDM and QuickTV and they both have "Capture Audio" enabled. I can't figure out what the problem is since they play through the programs normally with sound.
I'm using a...
Phillips Cap713x Video Capture
AthlonXP 2000+
Asus A7V266 (on board sound with Line In)
GeForce TI 4200
512MB Ram.
Anyone know what could be causing the problem?
Does your capture card use the PC's sound card to capture the audio? Some real early, real cheap units like the ADS USB Instant DVD used to go this route, and it's a lip-sync nightmare.
But I doubt any unit built since 2003 or so would do this. More info is needed about your capture card, since I couldn't find it on the Philips site.
NO sound when capturing with Ulead SE 11
By TheKillerQueen in forum Capturing and VCRReplies: 41Last Post: 13th Mar 2012, 03:55 -
sound interposition when capturing from tv
By eliqush in forum Capturing and VCRReplies: 0Last Post: 7th Oct 2009, 17:35 -
No sound when capturing video ???
By j4mes_bond25 in forum Capturing and VCRReplies: 6Last Post: 10th Aug 2009, 12:03 -
Capturing Audio in Sound Recorder
By ViRaL1 in forum Off topicReplies: 3Last Post: 2nd Dec 2008, 03:26 -
No sound while capturing from Sony Handycam to PC
By Tony11 in forum Capturing and VCRReplies: 1Last Post: 24th Jan 2008, 23:51
