Is there any utility that allows you to merge several DVDs into a single DVD while maintaining all the original menu & chapters ?
I have several DVDs that are only 1 GB - 1.2GB in size, so it is nice if I can back it up to a single DVD.
I only found 1 utility called DVDRemake Pro, but it not good for editing the disc title menu. It only says DISC1, DISC2, DISC3, etc. from what I heard.
Another question is whether the result will still be DVD compliant ?
You could always create a custom main menu after joining with DVDRemake Pro. I've done this a couple times and the default menu does look kinda corny. So I created a new one and used a combo of vobblanker and pgcedit to replace with the new one instead.
The only other way that I know of I've seen on doom9. If you want to check this thread out: http://forum.doom9.org/showthread.php?t=96211
Is there a guide to merging multiple DVD titles into a single output file?
By Lolipop Jones in forum DVD RippingReplies: 10Last Post: 11th Nov 2016, 20:19 -
Separate multiple title DVD into single title DVDs
By Dogpoundz in forum DVD RippingReplies: 4Last Post: 24th Aug 2011, 20:49 -
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 19:34 -
Converting Multiple Chapter DVDs into one single MP4 file
By djfreex2 in forum Newbie / General discussionsReplies: 1Last Post: 12th Jul 2009, 14:02 -
How do I import multiple dvds then edit them into a single compilation?
By bumblebee21 in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2007, 15:33
